Compact Professional Guitar Processor
BUY NOW
HX Stomp Step Beyond
HX Stomp is a professional-grade guitar processor that delivers the sound of Helix® amps, cabs, and effects in an ultra-compact pedal. Whether you prefer to play through a traditional amp-and-pedal setup, or go direct onstage or in the studio, HX Stomp seamlessly integrates into a variety of environments and applications. Utilizing the same DSP and HX Modeling technology as its bigger Helix brethren, the HX Stomp guitar pedal nonetheless fits easily onto your pedalboard, or even in the pocket of your gig bag. There are over 300 amps, cabs, and effects—including a looper. HX Stomp contains all the same HX models found in Helix family products, as well as the legacy effects library from Line 6® M-Series pedals, and stompbox modelers such as the DL4. Use it as a "super stompbox," a backup or fly rig, an add-on tone expander when combined with other modelers, an audio interface—or even a complete guitar or bass rig.
SUPER STOMPBOX
BACKUP OR FLY RIG
BASS RIG
TONE EXPANDER
USB AUDIO INTERFACE
HX Stomp Quickstart Tutorials
Connections
Here are just a few of the many ways to connect HX Stomp to other gear:
4-CABLE METHOD
PEDALBOARD
POWERED SPEAKERS
DSP EXPANSION
STUDIO
HYBRID AMP/DIRECT SETUP
HX Stomp
  or
Sign up to Learn More
HX Stomp
Super Stompbox
One powerful pedal
Barely larger than many conventional pedals, HX Stomp features over 300 amps, cabs, and effects from Helix, M-Series, and legacy Line 6 products—up to six simultaneously. Three capacitive-sensing footswitches with color-coded LED rings facilitate easy preset selection and editing. Connect optional footswitches and expression pedals for even greater control, and integrate your favorite pedals into any preset’s signal path by patching them into the two effects loops. You can also dial in amps and effects, save and load presets, and much more with the free HX Edit application*.
* Full HX Edit functionality for HX Stomp will be available soon.
Backup or Fly Rig
Play the gig with a single stompbox
HX Stomp is both a complete backup solution and the ultimate fly rig. Go direct to FOH or to any backline amp with ease—even use 4-Cable Method. Access up to six amp, cab, effect, and IR blocks simultaneously, so you’ll never have to worry about getting the tones you need. You’ll even be able to lay down tracks in your hotel room after the show using the built-in audio interface.
Bass Rig
Not just for guitarists.
HX Stomp offers a wealth of guitar tones in a tiny package—but there’s a lot there’s lot to like for bassists too. From stunning models of Acoustic 360 and Ampeg SVT heads to Mesa/Boogie Powerhouse and Sunn Coliseum cabs to effects such as the Musitronics Mu-Tron III and the Darkglass B7K Ultra—HX Stomp covers the bottom end. And this is flexible low end: Send your effected direct signal to the house while feeding a real amp, or create two entirely different signal paths for a dreamy bass tone that will still rattle the rafters.
Tone Expander
Add some HX magic to your modeler.
Place the HX Stomp guitar pedal in the effects loop of your favorite third-party modeler or profiler, and you’ve instantly added over 70 amps and 200 effects to your palette, including classics such as the Fender Bassman, Bogner Uberschall, Klon Centaur, and Maestro Echoplex EP-3. The six processing blocks in HX Stomp run in addition to your device’s own DSP power, so you gain up to six more simultaneous amps and effects. And in many cases, you can sync presets, tempo, and other parameters using a single MIDI cable.
USB Audio Interface.
Record, re-amp, and more.
With a generous 123dB of dynamic range, HX Stomp doubles as an ultra-low noise DSP-powered USB audio interface, offering 24-bit/96kHz multi-channel audio—and MIDI connectivity—for Mac and Windows® computers. There’s also a flexible input impedance circuit for realistic amp and pedal response, and built-in DI and re-amping capabilities. Adding the optional Apple Camera Connection Kit enables you to record directly to your Apple iPhone or iPad.
Mac, Apple, iPhone, and iPad are trademarks of Apple Inc., registered in the U.S. and other countries. Windows is a registered trademark of Microsoft Corporation.
