Line 6 FBV 3 foot controller with color LED rings, LED screen, and volume controller image
Next-generation foot controller for Line 6 amps.
Unleash your complete sonic arsenal.
FBV™ 3 is a next-generation foot controller that gives you total hands-free control of Line 6 amps and effects. Save and recall your favorite presets and much more. It’s the ultimate tool for performing guitarists. After all, you should focus on your performance—without being tied to the knobs on your amp.
Focus on your performance—not your gear.
When you’re performing, the last thing you want to worry about is your gear breaking down. With steel hardware and rugged metal casing, FBV 3 is built to withstand even the toughest gigs—night after night. A single cable supplies both power and communication to your amp, keeping your setup clean and simple. The illuminated and backlit LCD display is big, bright, and easy to read—so you can see the active preset name, number, and the chromatic tuner at a glance.
Line 6 FBV 3 close up of colored LED ring and durable foot switch
We thought of everything—literally.
FBV 3 isn’t your average foot controller. Thirteen steel footswitches—five with assignable color LEDs*—help you easily keep track of active amps and effects. Dedicated footswitches for bank up/down make it fast and easy to scroll through your presets. A built-in expression pedal with a wah/volume toe switch gives you even more control of sweeping effects. A dedicated tap tempo footswitch enables you to quickly synchronize time-based effects like delay and echo. And a chromatic tuner keeps every note sounding great.
Compatible Products
  • Spider V
  • Firehawk™ 1500
  • POD® HD Pro
  • POD HD Pro X
  • POD HD
  • AMPLIFi® 150
  • AMPLIFi 75
  • Spider® IV HD150*
  • Spider IV 15, 30, 75, 120, 150*
  • Spider Valve Mkii*
  • Spider III HD150, HD75
  • Spider III 75, 120, 150
  • Spider Jam
