THE ULTIMATE PROFESSIONAL GUITAR RIG EXPERIENCE FOR iOS
Take your guitar-based studio out on the road.
Ready to dial up award-winning guitar tones everywhere you go? Sonic Port™ and the Mobile POD® app transform your iOS device into the ultimate Guitar Rig, giving you on-the-go access to the Line 6® tones used on hundreds of hit records. Jam with the tones of your favorite artists. Record pro-quality tracks. Plug into your amp and play live. It’s the easiest way to experience amazing tone with GarageBand® and other Inter-App Audio recording apps. Featuring best-in-class quality and an arsenal of inspiring tones, Sonic Port gives you ultimate freedom to rock—anywhere you roam.
LEGENDARY LINE 6 GUITAR TONE
Tap into the sounds of your favorite artists.
For years, Grammy Award-winning producers have relied on POD tones—and the free Mobile POD app puts those same legendary tones in your pocket. Call up the right tone instantly with over 10,000 presets designed by artists, Line 6 and a community of other guitarists. Mix and match 32 amps, 16 effects and 16 speaker cabinets for a huge array of sounds. The intuitive interface makes it easy to tweak and save custom tones. Mobile POD even lets you play along with iTunes®* using your custom tones.
PLUG INTO iOS CREATIVITY
Use with iPod Touch, iPhone or iPad.
Sonic Port makes it easy to connect your guitar or bass to your iOS device and start making music. Simply plug your instrument into the studio-quality 1/4" guitar input, launch GarageBand, the free Line 6 Mobile POD app, another Inter-App Audio or Core Audio app, and start playing. Pro specs—up to 24-bit/48kHz audio quality throughout, and 120dB dynamic range on the guitar input—translate to full, powerful guitar tones.
Sonic Port brings pro quality stereo input and outputs to your iPod touch®, iPhone® or iPad®. Track keyboards, mixers, CD players and other iOS devices using the 1/8” stereo line input. Plug in your favorite headphones and hear your audio in stunning clarity. You can even connect powered studio monitors via the 1/4” mono/stereo guitar/line-level output.
AUDIO INTERFACE MOBILITY
Perform live while traveling light.
With Sonic Port and your iOS device, you can take the exact same tones from your home studio to the stage. Dial in your Mobile POD presets in the studio then use Sonic Port and your iOS device to replace a heavy, cumbersome pedalboard when you perform live.
Simply connect Sonic Port between your guitar and your amp using standard 1/4” cables—then use the Mobile POD app to instantly recall your whole effects chain for every song in your set list. It’s the easiest way to get the exact same tones every time.
* Tracks must be stored locally, and must not be protected by FairPlay® digital rights management.
iPod touch, iPhone, and iPad are trademarks of Apple, Inc., registered in the US and other countries. Lightning is a trademark of Apple, Inc. “Made for iPod,” “Made for iPhone,” and “Made for iPad” mean that an electronic accessory has been designed to connect specifically to iPod, iPhone, or iPad, respectively, and has been certified by the developer to meet Apple performance standards. Apple is not responsible for the operation of this device or its compliance with safety and regulatory standards.
SONIC PORT
FEATURES
  • 2-in/2-out audio interface with 24-bit/48kHz audio quality
  • 1/4” guitar/bass input with 120dB of dynamic range
  • 1/8” stereo line input
  • 1/4” mono-stereo guitar/line-level output
  • 1/8” stereo headphones output
  • Works with GarageBand, Jammit and other CoreAudio music apps
  • Powered by your iOS device—no additional power supply or batteries needed
  • Includes detachable 30-pin dock connector cable and LightningTM connector cable
COMPATIBILITY
  • iPhone 5s
  • iPhone 5c
  • iPhone 5
  • iPhone 4s
  • iPhone 4
  • iPad Air
  • iPad mini with Retina display
  • iPad 4
  • iPad(3rd generation)
  • iPad 2
  • iPad
  • iPad mini
  • iPod touch (5th generation)
  • iPod touch (4th generation)
MOBILE POD APP (FREE DOWNLOAD)
FEATURES
  • 32 amps, 16 effects and 16 speaker cabinets
  • Over 10,000 presets designed by artists, Line 6 and other players
  • Built-in chromatic tuner; Auto Mute lets you tune in silence
