JTV-69-US Buy Now
Expertly crafted in the United States, JTV-69-US places cutting-edge Variax® technology inside a premium instrument designed in the image of the first successful solidbody electrics. The classic ash or alder body, quarter-sawn maple neck with rosewood or maple fingerboard, and 25-1/2” scale length provide tonal richness and warmth while preserving the design's historic bright, percussive snap.
To make the most of this stunning tone, the humbucker in the bridge position complements the ‘60s-style single-coil pickups in the neck and middle positions. All pickups are loaded with alnico magnets and wound to James Tyler's specs. To complete the package, JTV-69-US features the comfortable Tyler ’59 neck profile; a James Tyler Custom Tremolo bridge; ultra-stable, quarter-sawn, three-piece maple neck; and your choice of classic and contemporary hand-sprayed finishes.
Head-turning Looks
The Extra Mile
