JTV-59-US Buy Now
James Tyler-designed Single-cut Guitar with Variax Modeling
Expertly crafted in the United States, JTV-59-US places cutting-edge Variax® technology inside a classic tonewood combination established by the archetypal set-neck, single-cutaway solidbodies of the 1950s. The figured maple top is carved into a gentle arch and paired with a mahogany body and quarter-sawn mahogany neck. This combination of woods yields the full spectrum of warmth, depth, clarity and complexity that has made maple/mahogany construction legendary.
A pair of alnico humbucking pickups translates this guitar’s stunning tone to the amp of your choice. They’re wound to James Tyler's specs in the image of vintage PAF-style humbuckers, but with expanded versatility for the contemporary player and a little extra output in the bridge position. To complete the package, JTV-59US features a unique Tyler-designed, fully adjustable wraparound bridge (which redefines resonant coupling between strings and body); a supremely comfortable neck patterned after Tyler's own '59 neck shape, with a smoothly contoured heel; and jaw-dropping looks courtesy of six hand-sprayed finishes.
See Full Features
Head-turning Looks
The Extra Mile
